Diff Dana 44 narrow track
- Featured
- 6
- Media
- 881
- Resources
- 193
- Solutions
- 59
- Central FL
Should I consider the pinion depth to be 2.403? Or just put the old shim thickness in and put the carrier in and start trying to adjust pinion depth by tooth pattern? Thanks for your help!I talk with my friend @ Yukon. They do not stamp + or - codes on the ring gear. As or the slinger, if you did not have one you do not need to add it. It will not hurt or help to put it on and YES you you have to adjust for the thickness.
New question. Does this model dana 44 have oil seals in the differential housing? If so do you have a part number? Getting a housing that had been already disassembled is a pain if your new to axles like I am. Thanks for your help!
