Dim tail stop light on right side
damname101
Recently i had an issue where there were no brake lights at all except for the tail lights which worked fine. I have been testing wires and voltage all day but no good. Suddenly the lights started working again. I now have brake lights again but on the drivers side they are very dim. when the headlights are on they are dimmer still. the passenger side lights are now working perfectly and very bright. i dont know what i did to get the brake lights working again but they are working.
again...on the drivers side the lights are very dim but on the passenger side they are very bright. i even replaced the bulbs with new bulbs. i have no idea except im guessing the left side has lower voltage. i think i measured 3.8v with the brake pedal pressed. bad connection? there is a plug that has 4 or 5 wires going into it and on the other side of the plug 3 wires come out and go to the left light.
i would just remove the connector and wire it directly but there is the issue of more wires going in than coming out.
can someone help me make sense of this please?
thanks
thanks
