distributor upgrade
Formula 40PC
I just purchased a 1976 CJ7 , it originally had a AMC 304 with quadtrac. From the research I have done some PO along the way has installed an AMC 360 with a build code of either 1968 or 1977 and a delco distributor from a 1970-1974 AMC Hornet marked 1112179 2F 5. From my research the early 70s AMC Hornets did not have an ignition model involved in the electrical system. They had the solenoid, voltage regulator, resistor, coil & distributor with a single wire going to it. I would like to know what upgrades are available for this ignition system, namely if the TeamRush upgrade can be performed on this system. I appreciate any help I can get. Thanks
