Engine Do I need any pats ? T176 to 258
toolow
Indiana
1980 cj7 258 4 speed
I have a 1980 CJ7 with a T-176 4 speed and a AMC 258 i6 / 4.2l . There's a little man with a big hammer inside.
I bought another 258 out of a 1983 cj. It had a T-4 Transmission . Will the 1983 engine bolt up to the T176 ?
Sent from my SM-G920V using Tapatalk
Solution
its direct swap just use ur original parts although I do recommend a new clutch and flywheel set if urs is used or questionable
Sent from my E6810 using Tapatalk
Solution
Thank you ! I had planned on the clutch and pressure plate. I also need to get a power steering gear box, The 83 has power steering pump .
buy a new/reman unit there cheap enough. dont forget to get a new pitman arm they are different. everything else is reusable
I also have a borgeson steering shaft. From what I've read the shafts on the power steering box are a different spline and diameter than the manual box. Can someone point me to which coupler I need ?
I believe the input shaft for manual steering is a 3/4" shaft and the power steering gear box uses a 13/16" inch input shaft with a 36 spline count. And BTW - When you count the splines, count half and multiple by 2 rather than count all the splines all the way around. That is because you need to extrapolate the count to include where the flat spot on the shaft is. So you will need a lower coupler for a 13/16" by 36 spline gear box input shaft to the Borgeson 7/8" DD shaft. Just for reference, the upper u-joint (if you need it also) would be for the 7/8" DD Borgeson shaft to the 1" DD steering column shaft. Any u-joint couplers with these dimensions will work. Doesn't have to be Borgeson parts. You can by the whole setup (not Borgeson) here for under $100: CJ Power Steering Shaft Kit or just get the lower Borgeson coupler part #034940. Here's one source: Borgeson 034940 Coupler
I got the engine in and it runs good, BUT I have a vibration when giving her the gas in 1st and 2nd. Its probably still there in 3rd and 4th just not as noticeable. I replaced the clutch, pressure plate, throw out and pilot during the
change. I did not change the flywheel because it was in good shape. Before I drop the Transmission and Transfer Case are there any other things I need to look at ? I will be checking the transmission mount, motor mounts this weekend. I have checked the u joints and have no movement . Pilot bearing maybe ?
Sent from my SM-G998U using Tapatalk
After checking everything ,the u joints, motor mounts and Transmission mount are good. I removed the rear driveshaft, locked the hubs and put it 4 wheel high. Went for a ride and the vibration is gone. Ordered a double cardin driveshaft. I think maybe the new engine changed the tilt of my Transfer Case just enough to give me bad vibes. I also ordered new rubber motor and transmission mounts but the old ones don't appear bad.
