Does the motor need to be supported?
40YearOldCJ
Racine, WI
1977 CJ5, 258, T150, D20, D30, AMC20
Does the motor need to be supported if the Transmission and Transfer Case are out? I was going to replace the clutch since I have everything out and I have a jack stand supporting the motor on the bell housing. I obviously need to move the jack stand to replace the clutch. I just want to make sure the motor wont fall out or wreck something.
I do not know if it is needed, but I just replaced my clutch last weekend and had a tranny jack holding the Transmission and Transfer Case while removing it and a floor jack supporting the engine at the oil pan. Just to be safe. Maybe you can use a jack stand if you don’t have another jack
YES.
As far back as you can.
