Drive train jarring while coasting in gear
1979 CJ5 | Chevy 350 | T-150 | Dana 30 | Performance Cam
In a failed attempt to locate source of my problem on the forum, probably for not using the right adjective (i.e. - drive train jarring, clanking, slamming back-n-forth etc.. ), I'll ask the question on a new thread..
Thanks in advance for any feedback!
While coasting in any of the 3 gears, I'm getting a lot of play (back-n-forth) slamming action from the rear end to tranny.
I'm sure some of this is attributed to the cam, causing a forward (jump) jerking action which then sends me on a roller coaster, slamming back-n-forth until i depress the cluch.
It only tends to happen when the tranny is aligned with the differential in a state when it doesn't know if it wants to accelerate or slow down.
I've had the rear end and pinion inspected; u-joints replaced. The tranny has been gone through as well.
I have noticed I have about 1/4 inch play when manually twisting the driveshaft by hand back-n-forth. but everything else seems tight.
I have read that this is normal, so long as there is not any up/down or in/out movement
Thanks again for any feedback that may help me pinpoint the problem area.
