Drivetrain fluids
It all takes the same thing the 75w-90 gear oil.
:agree:
Engine Oil:
Shell Rotella T-4 Conventional 15W-40 Heavy Duty Diesel. Do NOT use synthetic for oil changes. And of course use quality filters.
Coolant:
ZEREX G-05 50/50. ONLY use HOAT coolant and not recommended to add anything to it.
Differential Oil:
Valvoline 80W-90 Conventional Gear Oil w/ Limited Slip GL-5 #VV831. Do NOT use synthetic for oil changes. My rear is a Dana 44 .
Transfer Case Oil:
Same as differential. Valvoline 80W-90 Conventional Gear Oil w/ Limited Slip GL-5 #VV831. Do NOT use synthetic for oil changes. My transfer case is a Dana 300 . My drain plug was all routed out and was hard to remove. I removed it by slightly tapping on a socket and luckily it bit into it enough for removal. Don't bang on it too hard. Don't want to mess up threads on transfer case! Took some research to finally find the specs on it. Replaced it with a Dorman plug #090-026 1/4" 18 NPT however it does not have the magnet on it to trap metal bits on it. I can live with that for now.
Power Steering Fluid:
Use ONLY Dextron II or III compatible fluid. Do NOT use any Dextron compatible fluid higher than III. Something different about it. Do NOT use synthetic either. Because of all this I could only found locally CarQuest ATF #CQ420 that fit the bill.
Transmission Fluid:
Redline MT-90 75W90. GL-4. No one locally carried this or anything just GL-4 rated. Had to order. Only use GL-4 rated. Something about sulphur compounds in GL-5 not being good for brass parts on these older transmissions. I have a T177 4 speed manual transmisstion.
This is a rough blanket statement. Easy on the partial advice.
The Dana 300 requires either 75 or 80w - 90 GL4 gear oil only. NOT GL 5. The Dana 300 has brass thrust washers that the phosphorus and sulfur inside the GL 5 eat/corrode/ over time.
AMC20 and the Dana 30 are fine with 80-90w GL5. THIS is where you use a GL 5 fluid.
Not for sure on the T-176 .
slomo
Engine Oil:
Shell Rotella T4 Conventional 15W-40 Heavy Duty Diesel. Do NOT use synthetic for oil changes. And of course use quality filters.
Coolant:
Differential Oil:
Valvoline 80W-90 Conventional Gear Oil w/ Limited Slip GL-5 #VV831. Do NOT use synthetic for oil changes. My rear is a DANA 44.
Transfer Case Oil:
Same as differential. Valvoline 80W-90 Conventional Gear Oil w/ Limited Slip GL-5 #VV831. Do NOT use synthetic for oil changes. My transfer case is a DANA 300. My drain plug was all routed out and was hard to remove. I removed it by slightly tapping on a socket and luckily it bit into it enough for removal. Don't bang on it too hard. Don't want to mess up threads on transfer case! Took some research to finally find the specs on it. Replaced it with a Dorman plug #090-026 1/4" 18 NPT however it does not have the magnet on it to trap metal bits on it. I can live with that for now.
Transmission Fluid:
Wondering where this advice came from??
1.Shell is good oil. Ever better is Walmart Supertech 15w-40 at a much lower price.
2.HOAT coolant really? Far as I knew, these old Jeeps take the original green formula. I know that was the factory fill on them. Will HOAT hurt our Jeeps? Questionable I guess. For me, why not use what came in it? Been working fine for over three decades.
3.Your diff comment. If you have a Limited slip you need that additive only. All others just 80-90w GL 5.
4.Your Transfer Case suggestions, your mentioned Dana 300 has brass thrust washers. That requires GL 4 not GL 5. Will GL 5 kill the 300 overnight? Doubt it. Would I run it, no. Not when GL 4 is available. Also GL 4 is SAFE for brass slash non ferrous yellow metals (thrust washers). Is GL 5 safe on brass class?
5.power steering fluid, nothing wrong with plain old, wait for it, power steering fluid. You don't need Transmission fluid in a PS unit. Will it hurt it, nope. Proper fluid no since AMC never said to use it at all. Lastly you state do NOT use syn fluids here in this application. News flash, Dex II and III are SYNTHETIC. All of them. Not just one brand of it. Why, because it conforms to certain stanards for those fluids.
6. I AGREE on your trans fluid as a GL 4. Proper fluid YES.
slomo
3.Your diff comment. If you have a limited slip you need that additive only. All others just 80-90w GL 5.
4.Your transfer case suggestions, your mentioned Dana 300 has brass thrust washers. That requires GL 4 not GL 5. Will GL 5 kill the 300 overnight? Doubt it. Would I run it, no. Not when GL 4 is available. Also GL 4 is SAFE for brass slash non ferrous yellow metals (thrust washers). Is GL 5 safe on brass class?
5.power steering fluid, nothing wrong with plain old, wait for it, power steering fluid. You don't need trans fluid in a PS unit. Will it hurt it, nope. Proper fluid no since AMC never said to use it at all. Lastly you state do NOT use syn fluids here in this application. News flash, Dex II and III are SYNTHETIC. All of them. Not just one brand of it. Why, because it conforms to certain stanards for those fluids.
slomo
1. I understand saving money but this is my baby.
2. It's something about OAT coolant not being compatible and it creates sludge if mixed with other kinds. HOAT doesn't have that problem so that's why I stated to use that.
3. I agree that you don't need the additive if you don't have a Limited slip but I researched that it won't hurt if you don't have one. They didn't have the valvoline in the store without the additive so I bought the one that did.
4. "Apparently activated sulfate (used in some GL5 lubes) can eat brass synchros. Valvoline indicated: "The Valvoline High Performance Gear Oil 80-w90 can be used for both GL4 and GL5. The real concern is the type of sulfate used in the gear oil. You can not use an active sulfate for GL-4 applications. Valvoline uses an inactive sulfate that will not harm any yellow metal such as bronze. This allows our products to be used in manual transmissions that have bronze synchronizers."
5. I meant don't use "full" synthetic. They have synthetic additives in them but are not labeled as full synthetic. Sorry for the confusion.
6. Hey we agree on something!
I did research on what to put in my Jeep after I bought it. I love the internet! Saw conflicting opinions from forums, talking with car guys, etc. but this is what I decided to do. I realize there are different opinions from me and that's OK. I actually like being challenged because I might be wrong and I would hate to mess up. No one is always right. I appreciate the response. We all want to put the right fluids in our Jeeps right? We have to be careful since they are much older than the average vehicle on the road today with specs changing, etc.
****I realize there are different opinions from me and that's OK. I actually like being challenged because I might be wrong and I would hate to mess up. No one is always right. I appreciate the response. ****
Scorzany - Just wanted to say, this is the type of discourse that makes this forum great. Other forums with a difference of opinions expressed like this would quickly escalate to a major pissing contest. I think everyone should be required to read the above excerpt before each and every post.
Well said, sir.
