Drum to Disc, Where does the bracket bolt to?
- Orlando, FL
- 1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
I am in the process of doing a drum to disc conversion with this info AMC 20 disk brakes
I have cut the backing down to size, but the bracket that I bought doesn't seem to fit snug against the old drum brake backing. Is this the incorrect bracket? or do I need to grind it to a larger size to fit? It seems to fit nicely on the medial portion of the axle, but about 2 inches from where it meets with the backing it seems to flare out about 1/2 inch not allowing the bracket to fit into the pocket.
thanks in advance, any info will be greatly appreciated.
