E-core Ignition Coils and a Couple Other Ignition Questions
thundley57
I'm hoping some of you ignition experts can answer these questions:
I have the Team Rush ignition upgrade installed on my AMC 258 i6 / 4.2l ci engine which was a kit I bought from CRTPerformance and installed almost 2 years ago. The kit included the larger Ford dist cap/rotor/plug wires and an e-core coil. Several months ago I bypassed the resistor wire to the + side of the coil to bring 12V to the coil 100% of the time and not only during starting. CRTPerformance told me their coil could handle full time 12V and it was my understanding that the reason for the resistor wire in the 1st place was to protect the stock coil. Is this true? Yesterday my coil failed and I'm not sure if it was because I'm running full time 12V to it or not. I installed my spare e-core coil and noticed with the engine running the coil is very hot to the touch. You can keep your hand on it for maybe 5 seconds before it gets uncomfortably hot.
Is the fact that I'm running full time 12V to the coil putting any undue stress on my distributor components such as the pick up coil?
I'm considering replacing the e-core coil with the MSD Blaster high vibration coil (part #8222) and the installation instructions on their website state that a resistor must be installed if you have the stock, points style ignition. My distributor and ignition module are stock but I do not have points so am I good to install without the resistor? Have any of you bypassed the resistor wire as well?
One other question; I have a black wire coming out of the wiring harness near the starter solenoid that has a connector on it just like the red and blue wires that are connected to the ignition and start connectors on the solenoid (see attached picture). The wire is not connected to anything. Does anybody know what this wire was intended for?
