EFI fuel pump location?
OldsCool
Doing a Hamilton FI kit on my CJ7 and need some advice. Instructions suggest the pump should be as close to the tank as possible. It also suggests the pump be mounted as close to level with the bottom of the tank as possible. The difference in actual line feet from being closest to the tank vs. closest to level with the bottom of the tank is around 2.5 feet.
Which do you guys think is more important? Closest to the tank or level with the bottom? I've always heard closest to the tank but I'm new to FI conversions so I thought I'd ask those that have done it already done it.
If you've done a TBI swap, where did you mount your pump? Pics would be great, too!
