Electric fuel pump placement
Dan77CJ7
Denver,303Local
76' CJ-7 4.2L/T-18/d20 d30sua/amc20soa M/T MTZp3 35/12.50/15s mc2100
I replaced the electric fuel pump the PO had installed, with a heavy duty one it does mount the same it hangs really low. does the location of the pump need to be close to the tank, or can i mount the fuel pump on the fire wall? i can move the pump so the skid plate would protect it but i'd think i rather have it up out of the mud,water,snow. any thoughts? thanks.
Since an electric fuel pump is mostly better at pushing than pulling, the fuel is pretty much siphoned to the pump from the tank. To have a siphon effect, placing the pump as low as possible will allow the best operation. This also requires the fuel tank breathing system to be operational. The Mopar high pressure mpfi system has its pump right next to the fuel tank and the Howell low pressure tbi system has its setup as low as possible at a point close to the tank as yours is. You could check the siphoning system on your vehicle by removing the gas cap and the hose prior to the pump, it should flow freely. If you do not take your vehicle on the rocky mining roads Colorado is famous for you will be fine, otherwise you might want to move it up a bit.
Thank you sir. i moved the pump so it sit above the skid plate, maybe 1/16 higher then before.
