Engine Block Crack?
Engine Block Crack?
Neuner
Old Time Jeeper
The South
"Oscar":1985 CJ7, 4.0 '98 OBDII, T177, RE 4.5" lift w/ CV Jnts, Dana 300, Dana 30 and AMC 20, 33" BFG KO2s, Raptor Lined Interior and Rustoleum BBQ exterior.
Pulled the AMC 258 i6 / 4.2l and noticed an unusual jagged line/residue on the block below the manifolds. Was getting late and wanted to post the attached photo before I cleaned it up in case I loose track of it. Does it look like a crack?
Not sure if you can see it in the pic but it has a thin raised residue of oil like a mini mountain range that follows along the jagged line which is what caught my eye.
Take a steel brush to the area and clean it up.
Don't think it's a crack-
I agree, take a can of carb cleaner and clean it. Then take the metal brush to try to get rid of any scalling. May be the plug leaking and following a casting flaw.
Slow little dribbly leak.
