Engine mods
snapper7024
- Media
- 5
- Atlanta Georgia
- 1973 CJ5 304 STOCK, EVERYTHING FAR AS TRANSMISSION AND TRANSFER CASE IS STOCK AS WELL.
Anything from 400 to 600 CFMWhat would be a good size carb?
Generally speaking from my racing days. The key to mods of this type is to keep things in balance. A bad example is more easy to explain: Putting a "huge" cam but leaving the rest of the engine stock. You'd probably come out with much worse than stock performance.
However some things can help alone. Better breathing is a good start and easy to do. Headers and exhaust can be done without worry of degrading performance.
I wouldn't suggest a cam alone. When you get ready for cam then do the a carb, intake, cam (and likely fuel supply) at the same time and of similar performance specs.
You could also do any number of things to increase reliability. Radiator, electric fan, oil pump, new hoses/belts, etc...
~~~ on japanese jeeps ~~~
No I don't have experience with that specific cam.Meanwhile ... is there anybody have used this Crane Cams 272/284 before ? any good or bad experience with it ? ....
