    To dismiss this notice
    click the top right X.
Engine Mount question
thiswontbetooexpensive
Full Time Jeeper
Madison County, TX
1980 CJ5, Stock and original
258I6, Dana 300, T 176
(poor thing needs a little bit of time and a few kind words)
I was wondering if this:
and this:
are common issues for 32 year old CJ's?
I got the tub and "extra"wires off and noticed the apparent lack of structural integrity to the rubber engnen mounts. I will replace them when the engine is re-mounted after the fine folks at Vilas Motor Works complete their assignment. Might be a non-issue, but was going to check anyway.
Thanks,
Yes that is common, I just replaced mine this summer. You should do the Transmission mount also.
That was another thing I meant to ask about.
Is this suppossed to be all pushed to the rear of the vehicle like this? Again, I will take your advice on replacing both this and the engine mounts, but will that correct the alignment issues i see here?
Yes it looks like that mount is shot also. Its probably never been replaced.
I suspect the front mounts may have shifted to the rear.
Replace them all. Have you poked any holes in your oil filer lately? Pretty common when the mount fails.
I like the poly mounts. I kept blowing the rubber ones, I push the CJ hard.
Damn you thiswontbetoexpensive!! I just checked mine and they need replacing too!! :cool:
I guess I just saved you from finding out about that at a more in-opportune time then!
This won't be too expensive Dear! That's what I keep saying. Over and over again.
$40.00
  20.0%
