Exhaust leak on 79 258 engine
jp79cj
I recentl putchased 79 CJ7 with an exhaust leak on the exhaust manifold area. Removed intake and exhaust manifolds. Seperated them and cleaned the flages and any mating surface including the head. Chased and cleaned all threads on bolts and the head. Pruchased a Fel-Pro MS9982 gasket set and care fully followd the instructions. Facing the metal side of the gasket toward the manifold. Installed manifolds with anti-sieze on the bolts and torqued to 25 foot pound.Started engine and was very quite. Drove down the road and it started leaking under a load. Returned and checked bolts. thet were ok. The leaks is worse under a load and hot engine. Leak not heard on start up. Cant feel leak ant where . Added Marvel oil in carb to make it smoke but still not sure,
Any ideas or suggestion from someone with same problem or smarter than ME. HA HA
