Exhaust
so the motor is all in. I can't get it started. It has spark. There is gas, in fact to the point it almost sprays out of the carb.
Any Ideas?
check and re check your distributor. i have seen first hand a few of them put in 180 degrees off. check the timing too. make sure the timing marks on the crank and cam are exactly where they should be.
I rechecked the distributor and made a minor adjustment. Still no joy. I still have gas blowing out of the top of the carb. I guess my next stop is pulling the motor again , pulling the timing chain cover off and checking the timing marks. Anyone have any other suggestions?:(
