"EXPEDITION' Vs. 'OFF ROAD'...
TeamRush
Featured
So.West Indiana
'72 CJ
'Off Road' can be just that, a Dedicated 'Off Roader',
A Part Time 'Off Roader',
Usually fairly close to Civilization, and usually in a 'Group' of Off Roaders, or someplace 'Off Roaders' gather so you aren't completely stranded...
For me, 'EXPEDITION' vehicles need to have a LOT more attention to detail,
Tougher parts, trail repair 'Spares',
Tools to do that work,
And an 'Expedition' vehicle will often times be alone, so things like Self Rescue are important.
Now, since I plug around in the river bottoms WAY out in the 'Boonies' by myself,
If I want or need 'Help' it's often 10 miles or more to get help,
And there is no way a 'Tow Truck' can get to me.
To that end, I build more like an 'Expedition' vehicle than an 'Off Roader'...
Self Rescue.
1. Dual, Fully Isolated Batteries.
I used to mount a second alternator, or lug one around with me 'Just In Case'.
My 'Welder' was my second, but converting an alternator that will do serious welding is too large to fit in the 'Normal' alternator position on my V-8,
And lugging around a second alternator was a pain in the butt.
I've found out I can pack the alternator full of mud, and still run an entire weekend on Dual Batteries.
Dual batteries are fully isolated, combine with a 'Self Rescue' switch on the dash, and combine automatically when the oil pressure comes up.
2. Dual Starter Relays.
Since I needed a second Starter Relay anyway for dual batteries,
I feed both batteries directly to the starter when I hit the key.
No getting out to 'Self Jump'...
It's a simple matter to disconnect either battery in the event a battery fails... Which I'll cover below...
3. Dual Fans.
I kept the Mechanical Radiator Fan, Using a type with large blades that flatten out when I hit deep water so they don't eat the radiator,
And I installed a large Electric 'Pusher' fan in front of the radiator in case a fan belt breaks or I loose a blade and have to take the fan off the engine.
Dual water pump drive belts keep the water pump turning, so I don't have to worry about that.
4. Dual Fuel Pumps.
With VERY LITTLE valving, I'm running a mounted Electric fuel pump along with the Mechanical fuel pump.
I use the electric pump when the Mechanical pump gives up, or to draw fuel from cans, transfer fuel from tank when I need it.
5. Dual Ignitions.
My vehicles had VERY UN-RELIABLE ignition systems,
So I built a dual trigger distributor, run two ignition modules, two coils.
With the flip of a switch I can transfer from one ignition to the other without the engine missing a cylinder...
6. On Board Air.
I didn't want the brackets and stuff that went with a engine mounted compressor (My CJ's didn't come with compressors),
So I use a Viair electric compressor and some pretty large storage tanks,
One mounted under the body, One in the bed for a 'Lend Air' situation.
With the bed tank hooked up, I'm over 10 gallons of tank capacity, so this works well and compensates for the lower volume electric compressor.
On Board Air makes airing up and down tires a snap, but I also use it for tools and to pressurize my distributor, axles, Transmission & Transfer Case when I'm in deep water.
An air pressure regulator makes your system several times more useful.
7. On Board Welder.
Since I often have to do small welding jobs on the Jeep, as well as around the farm in the middle of nowhere, being able to weld from the Jeep is a great thing!
I use to carry a big old Alternator converted to weld from,
But now I mostly weld from the vehicle batteries, which makes things MUCH more simple and a lot less :dung: to drag around.
8. 'Lend A Battery' or 'Lend Power'.
Being able to pull a battery and stick it something else, or to use it around camp, lend battery/jumper cables to someone else makes for a really useful 'Upgrade'.
9. Winch.
A LARGE WINCH will take a lot of 'Battery',
So I use two batteries, which do most winching jobs quite well.
Since I already have two batteries for 'Self Rescue' and 'Lend' power,
It's a no brainier to use Heavy Relays to keep them isolated until I need them for winching.
10. Tools & Spare Parts.
The more things you can make your tools do, the better off you will be.
In an emergency, I will sacrifice my wrenches or jack handle to make parts, or to weld in 'Patches' to get me home.
One end flattened out makes a pretty good pry bar,
A socket extension welded to the side makes for a VERY long 'Breaker Bar'...
Having extra 'U Joints'/Straps, Fuel Rated hose (my air line), some extra hose clamps, and a small selection of parts has always allowed me to get back in without a tow.
Nothing like wacking off a piece of your air line to use as fuel line! Double Duty!
Jumper Cables made from welding cable make double duty for Jumps and Welding,
And lets not forget tow straps, clevises and the stuff you need for the winch...
I'm NOT trying to sell this as a 'HOME GAME', just trying to decide if this qualifies as an 'Expedition' Vehicle or an over equipped 'Off-Roader'...
"I'm NOT trying to sell this as a 'HOME GAME', just trying to decide if this qualifies as an 'Expedition' Vehicle or an over equipped 'Off-Roader'..."
__________________
I'd call you well equipped. Glad to see you back sir :chug:
WHERE GREASE IS, WATER AND CRUD CAN NOT BE.
The same goes for electrical connectors, Dielectric Grease is the best invention behind sliced bread and Duct Tape!
I find it's not the Primary Drive Train that gives up,
It's the small stuff...
Batteries,
Alternators,
Fans/Fan Clutches,
Fuel Pumps,
Ignition Components,
Wheel Bearings,
U Joints,
It's very rare that I run into someone with a cooked clutch, rod thrown out the block, broken Transmission or Transfer Case , axle gear set...
It's usually a wheel bearing giving up in the back and the axle creeping out the tube,
A front wheel bearing giving up,
An ignition module that quit working,
A fuel pump that gave up,
Broken belt on a single belt water pump,
Leaking water pump, now the engine is over heated (5 Gallon Can of water on the back for that particular issue)
By making the wheel bearings more resistant to crud, They live longer and work better.
By doubling up on what you can for reasonable money, you become 'Redundant' and you don't get stuck...
Working on something, got the wrong post up here but I'll replace it with information about the build...
Hi. I really like your tips. Thanks for them.
One thought I'd like to add. I'm a data center architect/engineer. I both design and do day-to-day support of thousands of servers for high profile customers. Bottom line is these servers can not go down ever so redundancy is very important. Recently there's been several trade articals on how too much redundancy actually makes redundancy worse. i.e. 2 powers supplies is good, but 4 would make things worse. It's all about statistics but the simple version is, there's always a chance one of your power supplies can go bad and take out the remaining power supplies. This is a very small chance and having dual power is statistically better, but as you add power supplies it comes to a point where the risk starts to overrun the benefit.
Anyway, the general rule is to have only 1 redundant part connected to any system. No problem having spares in your kit.
I don't have all the answers and my comments are just to get us thinking.
since it's you, I'll say well equiped "off roader"
Welcome back, hope you hang around awhile this time.:chug:
:ww:TR, glad to have you back,
Oh and what are your thoughts on oxygen/acetylene welders?
I'm not a 'Gas' welder, so I have none.
I'm a LOUSY welder, so stick welding burns through the rust, mud, crud and gets the job done. (Dirt Farmer Welding)
I did build an Alternator Welder that would Stick, TIG, MIG,
Also does AC welding, and High Frequency AC for aluminum welding (TIG),
But who wants to drag around a gas bottle in a Jeep for clean TIG/MIG?
Also seemed like every time I dragged it out and set it up, the wind would blow my shielding gas away and the welds looked like :dung: anyway...
The farm guys like it (some of them CAN weld) but I got tired of lugging around all that :dung: and went to 'Emergency' welding off the batteries.
A LOT LESS STUFF TO PACK AROUND!
Now it's the welding yoke, jumper cables, hood, gloves, rods and I'm off to the races. All fits under the passenger seat, so I'm good with that...
Excellent thread.
Thanks for the info.
:notworthy:
Thanks a ton!! alot of good info.
I've got 'How To' threads on most of this, if you need them, I'll post them...
Otherwise, they just take up server space...
  5.0%
