Facttory Radio CB AM/FM
Master7
Lucca Italy
CJ-7 Ex Golden Eagle, now is miscellaneous version personalized.
AMC 304 V8 4 Speed.
I don't know if this is a right section.
I had found a factory radio on ebay and now i want install it but i don't know if this is simple.
Please can you help me with a diagram wires, and instruction for install it?
If possible also with the pics, the antenna is necessary one or two (one for the radio and one for the CB) or it's ok use one antenna and one splitter for this?
Many thanks for your attenction, merry christmas to all of you.
My best regards.
Master7 (from Italy)
no, you'll never be happy with a combo antenna unit.. get a good whip for the cb, and a regular radio antenna for the radio.. you can put the whip on the spare mount on the rear..
if the radio is analog should be super simple. two wires for the speaker, unless it has an internal. then a positive and a negative
i will echo above, get an actual cb antenna for the cb. we had a tractor with a factory cb/am/fm. you couldnt pick up the truck beside you on the cb with a split antenna. put a 1.5 foot antenna off the roof and now its great.
if I remember correctly, my antenna was about 10' tall, used to have a clip on the front to pull it over and fasten it to when I went under low ceilings like gas stations, they frown when you take out their flourescent bulbs.. also, make sure to use the large chrome spring on the mounting.. its a white antenna, looks like fiberglass.. works great
go for a 107" wire whip antenna with spring... good times good times
My best regards.
if you can furnish a make/model number of the radio, I can tell you the wiring.. otherwise, its anybody's guess
The Radio is this:
Wagoneer 1980's Am FM CB Radio Factor Used Works | eBay
Can you tell me also if i can put only one antenna for radio and CB? and if
i must put for this a splitter.
The antenna can be place in the original right fender above "jeep" ?
Many thanks for your attenction!
Have a great day!
Master7
you'll need 2 antennas. one for the radio (am/fm) and one for the CB. the cb is coax and the radio uses the standard radio connector. the third picture i think shows both the coax and radio extensions.
