    Thank you for your support!
Build Thread Father son CJ Project
JimsCJ5
Gold Supporter
Atlanta, GA
1979 CJ5 Renegade 258, t-18 pretty much stock except for a later model aluminum intake manifold and Gronk 2150.
We've been working on this Jeep for about a year so I am a little late with a build thread but here's the story:
Bought this Jeep for my son for his 16th birthday. I paid $3,300 for a relatively rust free 79 CJ5 with the AMC 258 i6 / 4.2l . It was not perfect by any means but the paint was mostly original and it ran pretty good.
The plan was to do a military style CJ5 with out getting too crazy and to have it drivable for most of the time since he takes it to school.
The first thing to do was take stock of what we had. There were quite a few things the previous owners had done over the years that needed to be addressed.
First up was a cracked exhaust manifold. I took the advice of those on the forum and upgraded to late model aluminum intake. Much better. Soon after our exhaust guy installed a Flowmaster 40 and all new pipe exiting at the rear corner.
I bought a set of stock wheels for it for $100 and we went ahead and painted them the color we wanted. Olive drab.
The next thing we had to do was fix a leaking rear axle seal. This turned into an expensive fiasco and we ended up going to one-piece axles. We also took the opportunity to replace all the leaf spring hangers and bushings, paint the springs and re-do the rear brakes.
With that done the next project was to replace the rusty windshield frame.
We bought a repop frame but broke two windshields trying to install it. Finally figured out the repop frame has a smaller opening for the glass and after some work with the grinder we got the glass in.
We are very unhappy with the fit and will be installing a used stock frame in the near future.
Next up was bodywork and prep for paint.
And we are back...
Ok so we had a few body issues.
Holes cut in with a torch:
More holes and some rust:
Cracks and holes from a body mounted spare tire carrier
A decent sized dent on the right rear quarter:
I turned the kid loose on it with a borrowed MIG and some welding skills he had picked up at Boy Scout Summer camp:
Not bad for a rookie
Obligatory grinding shot:
Not bad results. Certainly not show quality but then we are not going for that
Body work done and scuffed and primed for paint.
Ok picking up where we left off...
We needed a paint booth so we cleared some trees, leveled an area off the driveway and put up a metal carport. The floor is crusher run which was watered and tamped down.
We had to time this pretty well since we were painting outside. We needed a warm day, dry with little wind.
The paint we used was Rustoleum (Hunter Green and rusty metal primer in equal proportions cut with acetone). We tried this on the wheels and really liked it.
First coat went on great but the color was off a little. Too olive.
After a quick confab the wife was dispatched to Lowes for more Hunter Green. We unded up with a ratio more like 2:1 but the color was much closer to what we had already shot.
You can see the difference here on the pieces of the blackout light.
Ok paint is on.
We are pretty happy with the paint. Not show quality by any means and there are dust specs in it but pretty consistent with some HumVees we looked at.
After paint we wanted to line the tub/ I took the advice of some here and bought some Monstaliner in olive drab. Again we had to wait for a warm dry day. While we were prepping it we discovered one of the seat belts bolts was too rusted to get off. We ended up cutting it out.
We welded in a new patch panel and applied the liner. Came out pretty good.
One item we had to fab were the headlight guards. We wanted ones that looked like the the M38A1 type so we bent up some steel rod and welded on some mounting tabs.
Next up was the rope. We used 1 1/4" manila rope but I think 1" would have been fine too. My son put in the eye splices and whipped the ends.
A new top and we can call it done.
We purchased a set of low back seats for it but they were too far gone to use and the original seats were no better. I think there was nothing but rust holding the frame to the mounts. We ended up using the original seats from my 65 mustang with some fabbed brackets. They look pretty good but will need to be recovered.
Some other things we did:
Mounted a blackout light to the left front fender.
Added a corner handle and custom license plate mount bracket to the left rear.
Sprayed undercoating on the wheel wells
Removed the plastic fenders and put SS button head bolts in the holes
Restored the gear shift knobs.
Replaced all the instrument lights and heater cables
Rebuilt the heater box and sprayed it with undercoating
Sprayed the inside of the hood with undercoating.
Etc, etc, etc.
Stuff we still need to do:
Front suspension bushings
Better mirrors
WS frame
Reupholster mustang seats in palamino
3 point seat belts
install a radio
Here are a couple of shots of the finished product. It's the coolest thing in the HS parking lot. It certainly has been a lot of fun.
A big Thank You to everyone on the forum. We could not have done it without all of your help.
Looks really good! You and your son should be very proud. As a Retired Army Veteran, I'd be proud to drive it. Rod
That’s cool that you and your son could work together on the project, and have it come out looking great.
Wow. Nice work. I am envious. I'm at the beginning of my search for a oldish CJ and it's great to see the hard work look so danged pretty. I only hope that I and my son will be as successful. Very nice job!
Very nice looking rig. I would have loved to have had something like that in high school. Something for both of you to be proud of.
That's nice work and the best part is your son will take good care of it because he knows the work that went into it.
Sweet looking lil CJ, y'all did yourselves proud :chug:
