fenderless rear tirewells
fishinfool98
Chat Picasso
Blounts Creek NC
1985 cj8 streched to 118in wheel base, shackle reversal soa, chevy vortec 350, turbo 350, dana 60 front and corp 14 rear, custom bumpers front and rear
2006 Ford F350 CCLB with the dreaded 6.0 that has given me no problems
so what do yall think, they still need a little work but there almost done
They look pretty good. Not much left to work out if you ask me! :)
i cut the factory body line out and that was it then took a piece of 1 1/4 x 5ft angle and cut and bent it until i liked the way it looked
If you do it start in the center and measure the flat part of the top of the tirewell ( this part was around 15 1/2 inches) then make 3 inch cuts from there
I only made 2 cuts on each side then take the same thickness flat plate and cut the little peices to tack in but wait until the piece is tacked in place where you want it before you weld the small filler pieces in, or you will have to do it again
are you going to flare the fender to stop the mud covering everything as the tire looks to be jutting out a long way ???
The axels are dana 44s out of a scout 2 so they stick out farther
not reall worried about mud slinging up on the sides, much less am i going to be able to stop it with the larger sized tires
looks like its going to be a fun ride
