Engine FILLER NECK ISSUE?
lil Mule
fuel filler issues.
Have not been able to add fuel to the 1980 CJ7 ,wont even put in a gallon? I've had this jeep for 5 years and only use the gas station down the block. It's never had an issue and I've never had a slow fill or had to adjust the pump handle.
Did a look around and did not find any kinked or collapsed hoses.
Pulled the filler neck and cleaned it up, it was pretty clean and all seems to be working fine. Filler and vent hose are ok.
Replaced the Charcoal Canister. Before I installed I blew out the line to the rollover and liquid check valve. Sprayed som compressed air and it blew into the tank.
Pulled the rollover valve and deleted just for now. Went to see if I could fill the tank and still it just pours out.
Any Ideas? Going to pull the lucid check valve tomorrow but I just feel like thats not it.
Can filler necks go bad? its all stock.
