Build Thread First Jeep 1984 CJ7 Laredo, Midland, TX
You can’t take the old ones out of the old unit ? Then swap them into the new part ? Also that garage area is going to be really nice.
WELL... that would have been the avenue, but time between taking apart and having bandwidth and in the cluster of a move moving the bench to the shop have put a damper on that. I'm going to look for the originals at the shop, but not holding out hope.
They look good, but my memory is a bit off on which side is the outside facing part of the stud, if it's the long bit that may just fit the bill. The ones those guys put on it remaning it are maybe 3/4" long but essentially and up flush with the back of the bracket. I'll order a set just in case i can't find the originals.
Good looking out thanks for the link!
Some basic dimensions are on the notes. But they may just be regular length and chrome plated.
Notes:
Includes two studs 3/8-16 thread and one bolt 3/8-16 thread. Fits most Saginaw and Saginaw P Series pumps. This set is the chrome plated set for use with chrome reservoir.
