flip the pitman arm?
noah
Pine Ridge, Arkansas
68 CJ5, Dauntless odd fire v6. stock dana 27 front, dana 44w/pwr lok rear, T98 transmission, dana 18 xfer case
Iv'e read alot about flipped tie rod ends, dropped pitman arms and was wondering if it is possible to flip the pitman arm.
I have a '68 CJ5 with a manual saginaw steering gear and with a 1 1/2" lift, there is a pretty good angle on the drag link.:confused:
The pitman arm has a tapper in the splines so it can only go one way on the sector shaft.
Guess it's the flipped tie rod ends. Thanks!
The tie rod isn't tapered, so flipped that. Worked perfect.
