Floor Heat
Floor Heat
Tin Medic
Ft. Carson
85 CJ-7 Renegade:
Fuel Injected 4.2L I6/T5/D300
D30 with ARB Air Locker, AMC 20 w/Posi
Warn 8000 LB winch
VIAIR Onboard Air System
33x12.5x15 Goodyear MT/R's
Kenwood head Unit
Hella E-Code Lights
What generates so much heat on the tub floor that it melts sandals and stuffed animals?
Almost certainly exhaust is causing your heat issues.
Is one area worse than others, could your exhaust or cat or muffler have been pushed up against or just closer to the floor?
I like the idea of the lizard skin products but haven't tried them. If it is one place you could try to shield it.
It's mainly the tranny tunnel and passenger floor.
It’s the Cat. The rest of the exhaust will obviously add heat but Cats get wicked hot.
If you need a heat shield take some measurements of the size you need then roll through the local wrecking yard and snag one from under a newer vehicle. They are easy to remove and are usually attached to the body.
if the cat is getting that hot it may be getting stopped up and need replaced
Probably going to remove the cat.
