Engine Flywheel condition
Sawjaws
Featured
Brooklyn Center, MN US
1978 CJ5, 304, T150, D20
Solution
Welp... Got it turned and it looks pretty good. Even got them to flip the ring gear for me since the starter side before was showing wear. Goes back on this evening. We'll See how she goes!
Replace it not worth the hassle and money. Luk makes a nice one for about the same amount as having one turned.
^^^^^^ X2
Well... I just spent the past hour looking for the right flywheel for this (5.0L AMC 304 V8) and apparently the only ones I can get that fit are a Hays (over $600) or an Omix (which I hear sucks, and I saw 2 reviews saying that it came out of balance from the box). So, I think this is getting turned.
Luk does not have any available anymore, not this specific one anyway. This is a 164 tooth external balance flywheel that is specific to the 304 V8.
Google suggests a bunch of model numbers, but they are all for the AMC 258 i6 / 4.2l V6 or the 360 or 401 V8.
I might be screwed... 😬
You can get a 360 fly wheel then have it match balanced by a machine shop.
My Nickel.95.....
At the 1:00 position, it looks like your Flywheel was a Major Crack just outside of the Bolt circle.
Bad News Bears !!
Replace the Flywheel especially if you value your ankles.
I got mine done and a new gear band or whatever that is called.
Solution
It Cleaned Up very well.
Good call to flip the Starter Ring Gear.
Keep us posted on the final results.
Well... The New clutch is in. Transmission and Transfer Case (with a new gasket between them) are installed. Both driveshafts with all new U-Joints (the bane of my existence until I finally bought a ball joint press) are installed. New release bearing, bellcrank linkage parts are installed and greased. Clutch pedal adjusted. Motor running and the rig is moving as it should under it's own power in the proper gears!!! I don't know if it's in 4 wheel or not yet, but the hard work is done and works well!
Great !!
A couple of rides on some stop sign side streets to "Burn the Fuzz" off the new clutch disc to "Seat" it on the Flywheel and Pressure Plate....
Trail Rides are a Waiting !!
$20.00
  10.0%
