FLywheel resurface-Do I have to?
jamesweed
- Chester county, PA
- '85 cj-7, 258, T-5, dana 300, stock diffs; 1967 Chevy Nova 2d HT
In the process of dropping Transmission I figured I would put a new clutch in while I'm in there. The clutch was OK just getting high on time. The Surface of the Flywheel seems pretty smooth, no grooves cut in as the clutch never got all the way down to the rivet heads. So Im debating as to if Im gonna machine the flywheel. Is it standard practice to machine it no matter what or a case by case call? What do you all think?
Thanks, JAMES
Thanks, JAMES
