Flywheel
Flywheel
STEVE1103
Pocono's PA
61 Jeep CJ5, F head 134, 79 Ford F100, 2012 Ford F150, 55 Ford F100
Should you always resurface a flywheel, and can you do it yourself, found a brake rotor tool for resurficing, was thinking of using it?
I say yes you should always have it done it doesn't cost that much to have it turned. For as much work as it is to change a clutch you want to do it right the first time.
Never seen a brake rotor tool that could do a flywheel?
But I agree with above, should only be 30-40 bucks.
