Flywheel
Flywheel
Dayle
Cedar Rapids Iowa
1984 CJ7 only mod motorcraft 2bbl no emissions on it after a fire, 195? CJ3B project have not start on it yet
Have a oddfire 231 stick. Have a 252 auto. Can i put the stick set up on the 252 from the 231? Thanks
odd fire fly wheels are balanced on the engine, so that flywheel works with that engine only, if you want a stick setup for the 252 you need to get a 252 flywheel and then convert everything else over. the 231 flywheel will not work on the 252.
