Fozen damper bolt on crankshaft
kadar
Ontario Ca.
67 cj5 V6 225 buick engine, D18 transfer case, D44 rear, D27 closed knuckle front with dualmatic hubs (style "D") and T86 trans.
I have pulled the engine out of our jeep and is now on a engine stand. I started removing valve covers, oil pan, water pump and now I'm trying to get the frozen damper bolt out so I can remove the timing cover. I"v tried heating up the bolt but no luck, I'm using a air impact tool but it still won't budge. Can anyone help. Thanks:notworthy:
sometimes trying to tighten it will help break it loose.
Kroil is a great lube to use.
You're sure the impact is up to snuff and you have good air pressure?
Thanks for the input all. Sorry i didn't get back to you sooner. I made a jig out of some angle iron and bolted it on the back of the crank across the engine stand to use as a brace and sure enought the nut broke loose. The block and heads are in the machine shop now getting hot tanked. New bearing and rings and value job. Hope I don't have to sell the cat to pay for the work. Thanks again for the support
