Fresh Air Vents on CJ7 like on FJ40
ColoradoCJ7
Denver, CO
Current - 1978 J20 401 auto, 1981 CJ7 304 5 speed and 2007 JK Uunlimited Rubicon all running 35" or 37" tires
Previous -1979 CJ7, 1984 CJ7, 1984 CJ7, 1997 TJ, 1990 YJ
Has anyone ever grafted a set of the fresh air vents from a Toyota FJ40 or something similar.
My dad had a FJ40 when I was a kid and you could just kick the floor vents open and it would scoop the air into the cab and I would like to do something similar in my CJ7 .
Here is a photo of what I am referring to:
IIRC, my '55 CJ5 had a set like that on each side. maybe look into an early Jeep catalog and see if they still sell them.
Ya know, that's not a bad idea. When I did my chevy heater upgrade, I closed off the plenum intake to keep the cab warmer (think Montana 30 below winters). So basically I have no fresh air unless I crack a window. This has had an effect on my inside humidity levels and windows fogging up...It was a good idea at the time. :dunno:
I am not stuck on that style I just like the ability to get more air moving when I want to and when those small openings scoop air it would blow the dust off the floor boards and really helped out. I know there are other examples you might know of.
Anyone know where I could get a set from the FJ or older CJ?
Yeah, try 4wdfibreglass in New Zealand (4wdfiberglass.co.nz should take you there)
E-mail Steve the owner- he'll be able to produce any parts you need and then ship them to you (size is not huge)
PM sent
Just noticed your in Denver I'm in evergreen
