Front Axle Question
Front Axle Question
JeeperChris
Old Time Jeeper
Michigan
'79 CJ5, 258 I6, T150 w/Dana20, Dana30 front and AMC20 rear. My first Jeep! I'm looking forward to doing some minor upgrades and restoration while enjoying the ride.
I was looking at my front axles today and they are just nasty. I would like to replace them so my question is: Are they good enough to just clean up and replace the u-joints or should i go with whole new axles? And then... which brand would you guys recommend?
Need pics
Sent from my SM-G965U using Tapatalk
Oh come on now, who on this forum has not seen a 40 year old axle before???
It looks just like the one that went through your mind when you read my post.
Maybe he hasn't seen a nasty one lately. :)
My leaks are fixed.
Ok, I did take pics, just gotta get them on here....
...just the outside.
After looking at the pics I think just changing them out would be best. Maybe new knuckles too.
They look corroded definitely. I would check the insides. If those are corroded then new axle housings if they look good cleanup the corrosion paint them and run them.
I think you should toss your axle in the scrap yard and get what you can for it. Then go out and buy a front 60 and rear 14.
Your kidding about your axle right? Nothing wrong with your axle, cleaning, maintenance, and paint is all you need.
Thanks guys, that's good stuff to hear.
I agree with Posi, my axles looked very similar when I stripped my CJ7 down to the frame. I’ve done some exploratory wire brushing to verify it’s just surface ugliness and sure enough, they’re fine underneath.
Just need a full brushing with a wire wheel and paint. I’m changing out my gear ratio and bearings and seals seals so not to worried about the inside.
You should be fine with some elbow grease and use the money you would have spent otherwise on dinner for your significant other. You’ll need that equity down the road.
Thanks, but it's just me right now. I'm hoping a nice running Jeep will help find me a significant other ;-)
Haha, nice. Best of luck. In the interim, use the money you’d save on the new axle for other Jeep parts
How long was the Jeep under the ocean...........:laugh::poke:
That ain't bad............
Pressure wash and get a case of Krylon flat black paint.
