Front axle shifted 2”
Hobiedad
On my 79 CJ5 I noticed the front axle had moved to the left which was causing my passenger tire to bump the leaf on a sharp turn. I pulled the springs off tonight and found the driver side spring out of alignment. Passenger side is straight. Crawling underneath I see no other reason for a shift.
Is what you see pictured enough to cause the axle to move that much? Do you think I can just knock the leaf back in place and tighten up those clamps and push the axle over and reinstall?
What else keeps the axle in position and straight?
