Frame Front leaf spring shackle in the way of aftermarket bumper
xtemplarx
East TN
1978 CJ5, 304, T18, D20, D30, AMC20
Trying to install an aftermarket front bumper on my '78 CJ5 , and i'm running into some alignment issues for the bottom bolt where it's supposed to mount to the frame. The top part of the shackle is in the way (and honestly, probably would be even with factory original shackles). See photos.
8e1b8095-2096-47e7-a2a1-948a4b404df7.webp 8eafb7b9-5785-46ee-9a64-82f9926b874f.webp 7cd65151-21b1-4b5d-862f-e44983199ffb.webp
Is my only real option to come up with some sort of bumper mount extension to push the bumper forward? I'm not a big fan of these shackles, but its what the jeep came to me with.
Those are some looooong shackles. Got any caster left?
My current front bumper from Fishbone had the same issue at extreme wheel stuff, when the shackles swing forward.
A little notching into the lower bumper flange with the 4-1/2" wheel did the trick.
I had to trim mine also. The bumper.
I think if I did the maths correctly it's about 1 degree for each inch. I could be very mistaken, but at some point I was trying to figure that out.
Is it me or are all the aftermarket bumpers made to fit CJ/YJ taller than the CJ frame? I have a YJ conversion spring kit and it also interferes with the bumper, but the bumper is about 2 thick, grade 8 washers too tall.
  100.0%
