Front sway bar link mounting pin removal
Sorry for bad picture. There is no load on that as it's already away from other end of sway bar link. I will give better swing tomorrow and remove whole sway bar if necessary. Got call from my friend and he told it might be really tight. Let's see how it goes...![]()
That is a tapered seat where both of those bolts reside...........with normal rust it may feel like its welded together.........Heat Yes , or it takes two people with two big hammers.........one against the force and one applying the same.
a small two jaw puller will sometimes apply enough force to break them loose.
