Fuel Injected Issue
Fuel Injected Issue
Well this trip to SD should be an adventure. :eek:
Switched to 91 Octane and she hasn't vapor locked since, but now she is running rough.
I'm having the same trouble Tin Medic. I have the MOPAR fuel injection conversion on my 1974 CJ6 . Probably did it 10 years ago. I'm on my third "Performance" external fuel pump, and it's going bad now. Driving on a hot day with warm fuel seems to make it worse.
The warning sign is the very audible noise the pump starts making plus the pump being hot to the touch. Shortly after the engine starts stumbling as air gets into the injectors soon followed by complete shutdown.
I'm pretty fed up with the external pump and joined this forum today with hopes someone out there has a remedy.
I was thinking a submersible pump may be the answer, which should keep the pump cooler and air out of the lines???
The external fuel pump does have its drawbacks. It requires that the fuel lines be clean an free flowing, this also requires a vented gas tank. In your case there might be an issue with the fuel pickup sock if you have one or a clogged fuel filter. It does sound like the is a problem with the fuel getting to the pump.
I am going to drop my tank and start from scratch, cleaning or replacing as I go.
Don't know about great but definitely needed.
