Fuel injection conversion
Hi I was wondering about a tbi on an iron duke is there a junkyard solution or the cheapest route?
I put a Holley 1D FI Projection kit on. Love it!
I got it used on eBay for $500. Holley still sells spare parts as well.
Uses new water temp, O2 sensor and a tach connection.
Fully programmable without a computer connected to the ECM. An air-fuel ratio meter really helps dial it in.
Hey 73CJ...
How did you mount the fuel pump?
I'm putting on a 2D this weekend. I have the wiring harness done but dont have a point on the frame lower than the 20 gallon poly tank. Did you mount your pump below the tank?
I just posted a new thread about it, and then discovered this post..
thanks
brian
This is how I do itWe use essential cookies to make this site work, and optional cookies to enhance your experience.
