Fuel issue
dtrojcak
I have a '78 CJ7 with the AMC 258 i6 / 4.2l
If I crank it every day, it starts right up.
If it sits for a few days, I have to crank for 30-60 seconds before it will fire up.
What I think is happening, is the fuel is draining back into the tank, leaving the fuel lines empty.
If I let it sit for a few days, it seems the fuel is also evaporating from the carb bowl.
I'm considering adding an electric fuel pump to fill the carb bowl, hopefully eliminating the long crank times.
My questions are:
1. Where should I mount the electric fuel pump? I'm thinking somewhere close to the existing mechanical fuel pump for ease of installation and wiring.
2. Should the electric pump be located before, after, in parallel, or in place of the mechanical pump?
I'm thinking of putting the electric on a switch that I would turn on before starting to prime everything, then shut it off once the engine is started.
Will the electric pump allow fuel to flow through it if it's not on?
Will the electric pump be able to pull/push fuel through the mechanical without the engine running?
If I install the electric in parallel instead of in series with the mechanical, will the mechanical push fuel backwards through the electric pump if the electric is switched off?
Or should I just bypass the mechanical all together and go with just the electric?
Will the electric require a pressure regulator?
I'm leaning towards adding the electric on a switch.
My thinking is that once the engine is started, I turn off the electric pump, and everything works as it always has.
I just need something to get fuel to the carb quicker when it hasn't been cranked in a while.
My questions are:
