Fuel Issue
Jroch
Greetings,
I have a 1985 CJ with a 343ci with a Holley Carb, I am not getting fuel to the carb consitantly, I have dropped the tank checked the pickup unit, ran new fuel line from pick up to carb, installed a new 9psig electric fuel pump, fuel pmp was orginally mounted on fender in the engine comparment moved to frame rail just behind the drivers seat, fuel line is aprox 4" from exhaust on the frame rail, tank has fuel in it, this is a single line fuel system not return to tank. I don't think it's a vapor lock issue but not 100% sure, I can run around the block with it and then run into the issue if I remove the fuel line from the carb I can pump fuel via the fuel pump with out issue.
Any and all assistance would be greatly appreciated as I am truely stumped on this
Justin
Justin
