Engine FUEL LINE sucking air
DHugg
MS Gulf Coast
'80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
Is the fuel filter return line at the 12 o'clock position?
you said it was a new 2100. NEW doesn't necessarily always spell Good. there is a chance that you have a leak in the carb or mounting plate allowing the fuel to run out or evaporate. since its the new part i would start with the carburetor.
Sent from my E6810 using Tapatalk
Thanks. I needed a starting place, and the poly fuel tank end didn't seem to be a good choice.
i have a problem with one of my 2100s where the float bowl will drain over time then the float will get stuck closed
