Fuel pump loosing prime?
mriplaybass
Full Time Jeeper
Now that the warm days are becoming few and far between, our 79 CJ7 is sitting for longer periods of time. There are, however, the occasional warm days, and we can't resist taking another ride before putting the Jeep to bed for the winter. Since we built this Jeep last spring, it has performed virtually flawlessly. But now, it sometimes sits for a week or more without being started. It recently sat for over 3 weeks following my knee surgery.
It appears as though the fuel pump is loosing prime when it sits for long periods of time. Everything in the fuel system is either new, or has been thoroughly cleaned. Rebuilt carb, new fuel filter, fuel pump, fuel tank sending unit and pick up tube. The fuel lines were all blown out, and the canister lines were replaced.
After sitting for awhile, all the cranking in the world won't start the engine. At least, I'm not going to crank until the battery goes dead
. All it takes to get the engine started is a shot of ether through the air filter, or a dribble of gas down the carb throat. The engine fires up and runs great. As long as I start it every few days, I never have to resort to ether or gas down the carb throat, but let it sit a week or more, and I have to "persuade" it to start.
I do have the float set a bit low to prevent spilling when on steep hills, and I am still running 45 jets from our Colorado trip instead of the usual 49s, but I can't see where either of these items could cause the carb bowl to dry out and the fuel pump to loose prime.
Any ideas
Any ideas
