fuel sending unit wiring
ftwflh
Crossville,IL
1976 CJ 5, 232 6cyl 3spd lots of rust,good frame,Dana 44s w/373 gears,ProComp 4in lift kit
should the hot and ground wires be on the same post?:confused:
The sender might have a spade terminal on it. It goes to ground.
The wire going to the gauge goes to the terminal on the sender.
A photo would help.
Disregard this post it does have the ground to a spade.
I did totally unhook the aftermarket gauge and it stays on full.Would think unhooked it would drop to empty.Stays on full all the time.
