Fuel System help
Keij
I recently purchased a 1986 CJ7 . it has not been run in 5 years so I took the following steps.
-Oil change
-Fuel filter
- Fuel Pump
- Valve cover gasket
-Cap,rotor,plugs wires
- air filter
- fogger/carb cleaner/rust penetrator
Now for my problem. After doing all that I went to start it just cranked. Poured a little fuel in carb, started ran for 20 sec. (Did that a few times) Unplugged hose from fuel filter no fuel at all in there.
I read another artical to remove line on pump from the tank and blow air till u see fuel coming out. did that hooked up the line and BOOM started for like 3-5 min ran and idled. At the 4 min mark I went to the back of the Jeep and fuel is pouring all over the ground....
Thoughts?
-Oil change
-Fuel filter
- Fuel Pump
- air filter
Thoughts?
