    To dismiss this notice
    click the top right X.
Full size axle swap
Full size axle swap
coldair
Full Time Jeeper
wyoming
1986 cj7 in the works,
1996 F350 crew cab with a 5.9 cummins
Been toying around with putting full size axles under my 74 CJ5 . have a friend with this done but i have never around it
Me too, but I am going to use Waggy axles instead to keep it kinda street legal.
Poisn Spider makes a kit to install full sized axles in a CJ Poly Performance JEEP/TRUCK & BUGGY*::*Suspension*::*Suspension & Lift Kits*::*Jeep Suspension Systems*::*1976-1986 Jeep CJ Suspesnion Systems*::*Poison Spyder Customs*::*Poison Spyder Jeep CJ Full Width Axle Conversion Kit - 4X4 Off-Road Parts, JK S
You have to mount the springs outboard of the frame rails like this:
Almost the entire wheel will fit outside the fenders so check your local laws first.
That kit says its for 76 to 86 my jeep is a 74.
http://www.jeep-cj.com/forums/f98/jimbos-1-2-build-thread-9967/
on post number 8 it shows the mounts I made to relocate the axles out side of the frame. I think I have about $30 tied up in the steel for the front (I got screwed on the price). those will get mountd to the out side of the frame. spring mounts will get wleded on for the rear and shackle mounts bolted on for the front.
$40.00
  20.0%
