Gas gauge
Swoop
- Gulfport ms
- 1984 Cj7, 258, T-4, Dana 300, Dana 30 in front and AMC 20 in rear.
Hello everybody I and new here but I have been reading a while and have learned so much from you guys Thanks I'm don't do the computer thing much so bear with me I only drive cjs so I have owned and built afew my wife say I bye them just to work on them lol maybe she is right lol owell what ever makes me happy right. OK here is what I need help with MY TEMP and gas Gauge are craze they use to go from cool to hot when I turned the key on and empty to full. the temp Gauge has always done that the gas Gauge goes where ever it won't. checked the wire in the back 12v on gas and 5v on heat I unplugged the Gauges and grounded both Gauges they go all the way up unplug them and they go down so I guess they work?? So I bought a new sender for tip and a hole sending kit for the tank installed all and now the temp Gauge does not work at all. just stays on cool the gas Gauge WORKS but not right full is full and empty is hafe. I ran a temporary wire to both Gauges still the SAME. new ground on tank SO I need help I took the motor out last weekend 4HOUR JOB GOT TO LOVE JEEPS SO EZ. REBUILT WITH GOOD CAM AND GOING TO INSTALL THIS WEEKEND BUT I NOTICED THE BODY GROUND THAT GOES TO THE BAT IS NOT HOOKED UP ITS JUST HANGING OFF THE FIRE WALL COULD THE BE IT THE FUEL TANK IS GROUNDED TO THE FRAME AND THE FRAME IS GROUNDED TO THE BLOCK SORRY ABOUT THE GRAMMER
