Gas leak ?
rwood, It most likely has an aftermarket tank since it's poly. If there is a 4inch-ish piece of metal in between the frame and tank straps it's probably a 21 gal tank. The most likely culprit will be a rotted fuel/vent line on the top of the tank. It could also be that the sending unit pickup assembly was not install correctly when the poly tank was installed. Either way, drain off as much fuel as possible and drop the tank. I would recommend changing all the hoses, including the fillers as well.
