Misc. Gas tank fill hoses
RiverandSand
I decided it was time get my fuel gauge working again. The gauge works, has full swing of the needle. On to the tank, dropped the tank, pulled the sender out, found the rheostat wire is broken, ordered new sender. Started to remove the rust off the tank, opened a pin hole under a chunk of rust, ordered new tank. Fill hoses look to be originals and are cracking and need replaceing. So here's the question, Omix and Crown hoses seems to be on most online sites, has anyone used them? I usually avoid those two because they are mostly
I ordered the tank from Summit, a Holley Sniper replacement, however they only show you guessed it Crown and Omix for hoses.
