gin poles front of jeep
dirtybird
austin tx
69 cj5 duantless v6
Pretty clever!
Nice! :chug:
Any chance you could zoom in on the mounts etc? Been thinking about one myself.
I was thing of putting a 4x6 or something between the frame and axle to take some of the load off the springs.
So that must be a heck of a boat! :D
I do not mind shooting fish in the face with an arrow! Ya know, Austin is just a short drive from Madisonville. We have some of the best bow fishing in the world! Even the river monsters guy came here to catch a gar. Just shoot me a PM if you care to get over this way. Got lots of friends that partake in the sport.:chug:
Interestingly functional.
Now back to the gin pole. Any chance for for detail photos?
I'm thinking of all kinds of uses for one. :D
I trying to get better pictures just been busy working and it's been dark when I get home
Check back tomorrow hopefully I will have th up by 12:00 pm ct
And the other foot too! LOL!:eek:
That looks like it is handy to have for lifting things. I usually use the bucket on a tractor, but these gin poles look as handy as a pocket on a teeshirt.:notworthy::chug: Good pics of mounting too BTW.
Thanks a lot. I see one in my future.
Never even thought about using angle for the pinning point.
Got some garage walls to lift this Summer.
And a dragline for cleaning some ponds. . and......
:D
Used angle because it was easier to drill one hole then to try and drill a hole through the pipe to match the angle of the pipe
Wish I had a bucket on a tractor hell wish I had a tractor
Also I used a concealing from roll bar to a gross bar 4' from top to raise and lower angle and then the winch to raise and lower load with a snatch block attached to the top
Was thinking that of you had two winches one on front one on back of jeep put a pulley or some kind of roller on top of the roll bar you could control angle and lift with two separate winches with the touch of a button
My poles are 2" thick wall 3/8" I think
the flex a little but was thinking that if your poles flex too much you weld a post perpendicular to the poles in the middle preload your pole in the opposite direction in which they will bend and run some 1/2 - 3/4" rebar from top to bottom and over your post and weld in place
It would keep the poles from bending at least
I have somethig similar that I slip into my receiver hitch in the front. I use my winch to pick up stuff
