GM nv3500
GM nv3500
JakeRod13
The South
78 CJ7
SBC 350
T150 tranny
d20 t-case
Has anyone had any experience with adapting NV3500 from a GM 1500 in a CJ7 with a sbc350?
Thanks Jacob
Thanks for the response. I can't find any info about adapting a GM nv3500 with a Dana 300 t. Case. Also, will it bolt straight on to the sbc (the nv3500 comes with an integrated bell house)
GM to GM should bolt up............check out Novak's site.
The tail housing is long and the Transfer Case bolt pattern is clocked wrong for the Dana 300 . Also, I'm pretty sure most of the GM NV3500s have a 27 spline output shaft. It might be possible to use the short NV3500 out of a Dodge Dakota with the 23 spline output shaft that will bolt to a Dana 300 and swap the front half of the case and input shaft from a GM NV3500. More parts to chase though. Post pictures if it works out.
