Build Thread Goin Postal
its sitting on a cj frame. I'm going to be boxing the frame I think anyways. I may not box it and just build a good cage instead (I'll be building a cage anyways). I'm not sure if just the cage would be ok or if the frame still would need to be boxed.
Good on the CJ frame.
Boxed mine. Time to do it when it's all apart. 1/8/" x 6" wide flat works fine. Cut a cardboard templet to fit, then mark out the steel. 1" on 3" stitch is fine for the welding.
Awesome thanks for the tip! I really hadn't even thought about the stitch welding. So 1" weld then 3" of gap to next 1" of weld?
Also jumped in feet first in the YJ swap. Ordered all my bracketry, mounts, and lift through Morris4x4. They were giving out free stuff so I got 2 shirts and a 75 piece tool kit. Plus had the stock leaf/shackle hangers I wanted. I bought the Rough Country 4" YJ lift with Nitro shocks. Besides the leaf hangers the only thing I'll have to modify is the front shocks, the YJ has stud mounts on the top where as the CJ's are eye mounts. I'll likely put some box tube up there and drill a hole for the stud to go through.
You know, I may not even take out the body lift.
I stopped reading here. Please get rid of it and re fab your fuel cell location. Ok so I read slightly further. :)
haha, we'll see what happens. I want to mount a 3rd bucket in the back, and without the body lift thats going to be nearly impossible. No question though if its stupid tall the body lift is coming out. For now, it stays.
Got it home today!
The d20 twin stick brings me to my next question. My d44 axle is offset, can I run a d20 (no offset output) tcase to my offset d44 on my short wheel base cj5? I'm missing the whole rear axle anyways, so I need to get a new one from somewhere….
It Looks to me like you have a D-18 offset Transfer Case to go with your offset Dana 44 rear end.
I don't think you can use a Dana 20 tranfer with that offset rearend
I had heard from a few people that it was ok, but I don't know. I found a set of wide trac axles, Dana 30 and AMC20 for $200. Thinking about that, then I'd just go right into having the Dana 20 as my tcase. Is $200 a decent price for the two axles? The Dana 30 is missing the lock outs. Maybe I could put the lock outs on my jeep currently on the widetrac?
If the existing D-18/Dana 44 combo is seviceable, I'd stay with that.
I wonder if it would be worth changing out the front axle. I would like to ditch the bell crank steering setup and those silly knuckles. Also the front brakes on my existing axle are frozen. I'd rather not spend more money on that axle especially if it's not going to hold up at all.
Plans for this weekend
Get furnace hooked up, its snowing up here!
clean garage
get front springs mounted up. I'm not going to weld on the new spring perches for the axle because I'm seriously considering swapping over to a Saginaw steering box and Dana 30 front axle. For now I'll use this closed knuckle for mock up purposes. I'm going to mount the springs as a shackle reversal as well.
Maybe get the rear end started on and remove the springs.
Maybe start pulling the 3" body lift. I remembered I bought greasable shackles, and turns out they are going to be about 1" of lift on their own, plus 4" on the leafs, plus 3" on the body = stupid.
you will go through ujoints right and left if you put a Dana 20 with an offset Dana 44
that D18 is one of the strongest tcaes ever made. have it rebuilt and attached to your tranny. (let them marry it please, to many small pieces you can be chasing if yo do not)
I swapped in a Dana 30 and made a hybrid steering system, I may go saginaw in a few years but this system is working fine, there is another alternative to saginaw that works real well also, it is the reversed Ford steering box mod, a lot more modern than saginaw and a bit easier to do
Steering Components
Thanks for the tips. Unfortunately I can't get this furnace to work, so thats all the farther I got today and tomorrow I have to work on other :dung:.
The only reason I wanted a Dana 20 was for a twin stick. I'll leave the d18 in there though if I'm going to have to fight with ujoints and vibrations.
I know I wanted this to be a simple build, but as always it has snowballed into something more. Not that its not doable and I have all winter, but I would have liked to not have to mess with the steering and potentially axle(s). I can't get the stupid steering column in the box anyways. There is a chance its not the correct column, but I think it is. Just can't get the washer on the bottom of it past the two pins in the box.
Sorta fixed the shackle angle. The shackles are pointed a little bit forward now, I know not ideal by any means, but I think I'm going to leave it for now and see where the springs sag to.
I was talking with a guy from my area just now about finding a Dana 30 and steering setup. Figured out some things. Pretty positive now there was a 4 cylinder in here before (thought so but now even more certain), figured out I can use the d27 front axle and mate a drag link to it with some mods and fabbing so I can keep that axle and go to a saginaw steering box, and I looked at my axles to see the gearing to try and match up a new axle. Well the tags both read 5.36! I was pretty excited.
New plan, even more solid than before, is to not use the amc 360 (suppose I jumped the gun on it anyways ) and I'm going to find either a 4 cylinder for direct and easy install or the 225 v6. Anyone have a 4 cyl?
I'm also going to keep both of these axles because of the gears and because I already have them, no wasting. Apparently the d27 can be swapped to disk brakes, put the bigger drums on the Dana 44 , then I'll find a wagoneer brake cylinder and not run power brakes for now. See how it works, sounds like they work plenty strong. On the steering front, I guess its not all that difficult to mod the knuckles to make use of a high drag link mount. So as of now thats the plan. Should be easier, work well, and be cheaper to build than swapping axles and installing the 360.
