Going to look at a 78 CJ-7
NEPACJ7
- pennsylvania
- 1978 CJ-7
304v8
automatic transmission
quadra-trac
Hello everyone, I am new to this forum but I am not new to CJ's. My first vehicle was an 84 CJ7 with a AMC 258 i6 / 4.2l , T-4 manual, 2.5 inch rancho suspension lift and 32's. Since having that I have owned and run various 4x4's and am ready to go back to a CJ. While joining this forum I listed a 78 CJ-7 as my vehicle however I do not have it yet. I am going this weekend to look at it as I have only had it described to me by the person who is trading it for my Land Rover I currently drive.
I am going back to a CJ because I am sick and tired of driving something that is computerized and has overpriced parts even though it is 13 years old. I want to go back to doing 90-100% of the mechanical work myself so I can have more pride in what I drive. I will have all of the information on the Jeep by the end of the weekend as well as images. The only problems I have been told are the following:
1.Brakes need to be bled, brakes are brand new, just not bled yet. (no worries I have done this on every vehicle I have ever owned.)
2. Transmission filler tube needs an o ring as it leaks (once again nothing major and easy fix)
3. Holley 2 barrel carb needs to be adjusted and possibly rebuilt, was told that it will start and run but sometimes that it stalls/cuts out. I will have more info on this over the weekend.
4. Possible valley pan gasket replacement.
It's lifted with new tires ( I believe 36's) has a soft top and full roll cage, wrangler tub and one piece CJ tilt front end. it does have quadra-trac and an automatic transmission. The transmission is not the original one. The original one went out and another one put in, but not sure if it is the same kind, assuming it is because of the quadra-trac. I will be going this weekend and will post an update on everything. One thing I am curious about is I do not believe it has cats on it as it is dual exhaust with headers and glasspacks, however I do not have to worry about emissions testing but I have not been able to find a straight answer on whether a 78 with a AMC 304 came with them or not. I found info on the 258 in the 70's not having them.
